Hi!
I have .hu domain but i can’t register on c-panel.
On domain host i can’t change nameservers because a SOA record so how can we or i make manual domain add?
Hi!
@TeddHUN said:
Hi!I have .hu domain but i can’t register on c-panel.
Hi,
Please read this KB:
https://infinityfree.net/support/add-your-own-domain/
@UnknownLolz said:
On domain host i can’t change nameservers because a SOA record so how can we or i make manual domain add?Hi,
I kown this.
But in .hu domains we can’t nameservers first…
Tell us what your registrat wants from you so we can help you.
Actually looks like this issue https://infinityfree.net/support/unable-to-set-nameservers-dns-query-refused/
So, i can’t make it?
Yep! as mentioned in article currently there is no way to use infinityfree by using DNS records instead of nameservers.
nameservers are required to be propagated to the infinityfree nameservers else you will not be able to get hosting for your .hu domain name. Can i know which registrar you are using because the one i found on google is providing nameserver function with .hu domain name. Yes, nameservers can be changed at will after registration, although they may take up to a day to be properly effective.
