I opened an account and requested a new Free SSL Certificate (Google Trust) that has already been installed and is active. However, every time I try to install Wordpress (through Softaculous) using the “https://” the installer tells me that “A trusted SSL Certificate was not found”…
Hi and welcome to the forum! Just ignore that warning and continue installing WordPress as normal; your website will work anyway if you’re sure you installed the certificate, it’s just that Softaculous doesn’t recognise it.
