A trusted SSL Certificate was not found
Hello everyone,
metropol.tech
When I create WordPress I got the message ‘A trusted SSL Certificate was not found’ however everything is setup correctly in my control panel (see screenshot),
The SSL was requested from infinityfree tool.
I suggest you to ignore that message, because Softaculous doesn’t know which certificate type is, but after WordPress is installed you can access your website through HTTPS.
When I try to access with https://metropol.tech it doesn’t work it shows: " This site can’t provide a secure connection"
Then you’ll have to install the certificate on your hosting account for your domain. The instructions to do that are here. Just follow the part named “Installing an existing certificate”.
Thank you very much sir, it worked.
