Username epiz_27016212 - Website URL esteehandmade dot com
Problems installing WordPress on https://esteehandmade.com
A trusted SSL Certificate was not found
I already setup the SLL certificate both on my cPanel in InfinityFree hosting and within the cPanel of the domain provider. The SLL certificate is by Let’s Encrypt it’s 2048 bit and it is ACTIVE in both places.
However - I tried installing WordPress trough softaculous app installer in the InfinityFree cPanel and I keep getting the same error message again and again - “A trusted SSL Certificate was not found”.
When I go to https://esteehandmade I do see a greeting page and I read some suggestions to ignore this error message and go ahead with the install - that didn’t work.
I tried also installing WP on HTTP and then changing it to HTTPS trough the WP admin panel - that also didn’t work.
I checked MySQL database and it was set to - https
Yet every time I tried I could only get WordPress on HTTP… The HTTPS version of my website is stuck showing the same greeting page.
Please can you look into that issue and tell me what to do because I really can’t think of anything else - as I said I have tried everything that has been previously suggested on that topic.
Thank you.
