Hi, I wanted to tell you if you can use many websites per account, that is, is it against the rules?
Hello there,
There is a limit on hoe many websites you can have per account, you can only have 3 websites per account. If you want more, you may want to consider buying the premium plans.
23. MAXIMUM FREE HOSTING ACCOUNTS PER PERSON
Registering more than three accounts is considered abuse and will result in all accounts being terminated without notice.
~ Terms of Service (ToS)
Ok, I don’t want to create more than 3 accounts.
You cannot create more than 3 accounts, but if you just want to host additional domains add them to your add-on domains section In the control panel.
Thanks a lot!
Also, you can have up to 400 MySQL databases
