A few questions
Hi. I’m a newbie to the tech world but I was basically trying to set up a wordpress website with infinityfree hosting, using a domain from godaddy and ssl(for https) from cloudflare. My domain on godaddy for quantumfrequencies [dot] com now says " DNS ONLY-off site) and is unavailable. My other domain on godaddy is quantumfrequencies [dot] xyz and it is available. At this point , im very confused and i believe my godaddy domain for quantumfrequencies [dot] com is no good. I also had quantumfrequencies [dot] com and quantumfrequencies [dot ]xyz set up on cloudflare, but I recieved a message saying that quantumfrequencies [dot] xyz was deleted, with quantumfrequencies [dot] com is pending nameserver update. Yesterday I placed the infinityfree nameservers into my godaddy dns and thats when i recieved this email from them:
"Your off-site zone for [quantumfrequencies [dot] com] (http [://] quantumfrequencies [dot] com/) is ready. Please replace the nameservers at your current registrar with these:
[ns53[dot]domaincontrol [dot] com] (http] ns53 [dot] domaincontrol [dot] com/)
[ns54[dot]domaincontro l[dot] com] (http] ns54 [dot] domaincontrol [dot] com/)
I contacted godaddy and they said I should reach out to infinityfree to make these changes. I also set up an infinityfree account for quantumfrequencies [dot
] com and quantumfrequencies [dot] xyz but I only see the account listed for quantumfrequencies [dot] com, so Im wondering if I accidentally deleted the .xyz account and can I retrieve it because I still have a domain available for that on goddaddy. I tried to create a website through infinityfree for quantumfrequencies [dot] com, but it wont allow me to do so because no domain shows up for the app to be installed onto. PLEASE HELP!!!
Also…you may find this email I recieved from cloudflare helpful in assisting me with these matters…
The zone: “[ quantumfrequencies [dot ]xyz] (http [://] quantumfrequencies [dot] xyz/)” in account: HIDDEN BY MOD was deleted by HIDDEN BY MOD on 2020-03-15 19:52:55.234582+00.
I’m not sure if this is due to a mistake on my part but I’m willing to start over. I still have an available domain name(quantumfrequencies [dot] xyz) and I could start with that if necessary. thank you for your support.
I checked the domains quantumfrequencies.xyz and quantumfrequencies.com and neither of them are pointing to our nameservers or assigned to any hosting account. In fact, all the accounts you have now don’t have any domain names assigned to them at all.
So from here, you basically can start from scratch like so:
https://infinityfree.net/support/add-your-own-domain/
i followed your advice and simply created a new infintyfree account for quantumfrequencies.epizy.com, but after installing wordpress , both the sitelink and admin link take to to a blank epizy.com ad page .please help
https://infinityfree.net/support/why-doesnt-my-domain-work/
my godaddy domain is quantumfrequencies.xyz. i was sucessfully able to link it with cloud flare but now i cant create an account on infinity free. i tried to set this account up on infinityfree yesterday for quantumfrequencies dot xyz but it keeps telling me that my nameservers need to be pointing to ns1.epizy dot com and ns2.epiz dot com. and ive did this several times and nothing has happened. please help.!!!
my godaddy name servers were changed to cloudflare nameservers, which was successful, but now when i try to activate infinity free account it keeps telling me to make sure domain nameservers are pointing to ns1.epizy dot com and ns2.epiz dot com. should i remove the cloudflare nameservers in godaddy and replace it with these or what?? and if i remove the cloudflare nameservers from my domain account, will that remove my ssl license?? im very new at this tech stuff and don’t really know what I’m doing. can you please give me some help on how to resolve this???
To add the domain to a hosting account with us, you have to remove ALL other nameservers from your domain, and only put ns1.epizy.com and ns2.epizy.com there.
After that, you should be able to add the domain name to your account. Although note that it may take up to 24 hours for the nameserver changes to take effect.
Once the domain name is added to your account, you’re free to move it to other nameservers. But your domain must point to our nameservers to add it to an account.
i had everything set according to your instructions and my website was working , but not secure. so i tried to add cloudflare ssl for ssl and https with padlock and thats where the problems came. now my website isnt available. i contacted cloudflare and they sent me this message…
"Your DNS records are set correctly and working as expected.
I can see your website returns a 404 error.
A 4xx Client Error is a client side error that means that the client sent something the origin was unable to process. Cloudflare does not generate any 4xx error code, so this would indicate something is not configured correctly with your hosting provider or your client is sending something incorrect. The best next steps would be to have this client generate a HAR file and send this to your hosting provider to identify what potential misconfiguration could be in place.
Can you also confirm that the website origin IP 184.168.131.241 it correct?
If you have any more questions, simply reply to this email and we will be happy to help."
so now im lost and confused again… can you offer any assistance to resolve this please???
No, that IP is not correct. You can find the IP to use by following this KB article.
