429 Too Many Requests - Scanner activity detected
https://revealjob.freedev.app/abs/
I couldn’t find an article or staff answer that explains this specific “Scanner activity detected” 429, so I can’t say yet what’s triggering it.
Two things would help narrow it down. Does the 429 appear when you open the site in a private window on a different connection, such as mobile data? And did anything other than a normal browser request the site shortly before it started, like a script, a monitoring service or a security or SEO scanning tool?
The knowledge base article below covers our browser security system, which is what adds the ?i=1 to your URL. It doesn’t mention a 429.
The HTTP error code 429 typically points to a rate limiting error, meaning too many requests came from your IP address in a short period of time. I don’t know exactly how this “scanner activity detection” system works, but it’s probably some way related to rate limits.
The good part is that you probably don’t need to do anything to fix it, just give it some time. In the mean time, you can try to access your website using a different connection, like mobile data or a VPN.
