My website URL is: mkaroune.ga
What I’m seeing is:*
I am trying to connect via fileZilla but I am getting the following error. I think it is a common one. I have read some posts but I did not find the answer.
Statut : | Attente avant nouvel essai… |
Statut : | Résolution de l’adresse de ftpupload.net |
Statut : | Connexion à 185.27.134.11:21… |
Statut : | Connexion établie, attente du message d’accueil… |
Réponse : | 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- |
Réponse : | 220-You are user number 478 of 3900 allowed. |
Réponse : | 220-Local time is now 01:24. Server port: 21. |
Réponse : | 220-This is a private system - No anonymous login |
Réponse : | 220 You will be disconnected after 60 seconds of inactivity. |
Commande : | AUTH TLS |
Réponse : | 234 AUTH TLS OK. |
Statut : | Initialisation de TLS… |
Statut : | Vérification du certificat… |
Statut : | Connexion TLS établie. |
Commande : | USER epiz_24677864 |
Réponse : | 331 User epiz_24677864 OK. Password required |
Commande : | PASS *********** |
Réponse : | 421 Home directory not available - aborting |
Erreur : | Impossible d’établir une connexion au serveur |
Thank you.
