Ill try that right now
Still the same error after removing and adding back my domain . I made a test.html file in my htdocs file too see if it would read when i sear it up with https://nathanielraymedia.com/test.html
But it still shows the 404 error still
hi @Nrapid11
probably a silly question, but have you made any unusual changes to your wordpress config? (Am I right in assuming its a wordpress site?)
I’m genuinly running out of ideas as to what could be causing this error
nope, i didnt make any changes. I just ffinished editing one night everything was good then the next morning the 404 started happening
Has you been editing a specific post?
did that post use any kind of special characters or emojis?
I’m wondering if the post you were editing has become corrupt? might be worth (if you can) going into the data base from your account dashboard and removing that post to see if that fixes it?
Otherwise you might be down to reinstalling wordpress ![]()
From reading about on the interwebs, the most common cause of this error seems to be related to permalinks
not that that helps if you can’t get onto the site to fix it
https://www.cloudways.com/blog/wordpress-404-error/
This should be the proper guide for broken permalinks
