404 / Not Found
http://honalond.infinityfreeapp.com/
404 Not Found
The page you were looking for could not be found!
I use the Laravel framework in this project. The project works completely efficiently on the local host, and I checked all the files. Immediately after uploading it to the hosting, there is no page that wants to be displayed other than the home page. When I try to access any other page, I get a 404 error message.
I checked all files and letter case and they are all working properly!,
When I try to change the link to the home page to take me to the contact page, the page works properly, but when I try to access the link to the contact page itself, I get an error message.
No issue
It appears when you try to access the contact page
Check this out then
Do you have the correct laravel .htaccess uploaded as well?
Oh my God, here was the problem
Due to their large size, the project files were uploaded to FTP. I believe that this file was not transferred. Thank you very much, my friend. The problem has been solved. :heart:
