404 Not Found and SSL not working
https://jarullahi.com.ng
404 Not Found and SSL certificate not working.
The IP you listed, 185.27.134.11, doesn’t match the one on your account, which is 185.27.134.131. If you typed that IP into an A record at Whogohost, that could be the problem. With InfinityFree’s nameservers you shouldn’t need an A record there at all. Could you check which one is set at Whogohost and tell me what you find?
I’d also like to know exactly what the 404 page looks like. Please paste its text, or say whether it’s a plain browser error or a page with a logo or a server name on it. That tells us whether the request is reaching our servers or going somewhere else.
You also didn’t give your InfinityFree username (the post still has the placeholder text). It isn’t strictly needed, but if you want to share it, edit the post.
For the SSL, here’s the article on getting and installing a free certificate from the client area:
I can’t confirm the certificate request will work until the domain is clearly pointing to your account. Sort out the 404 first, then try it.
Thank you for checking!
Yes, you are correct. My account IP is 185.27.134.131, not .11. I made a mistake.
I have now fixed it at Whogohost/GO54:
I have saved it. The 404 page I was seeing was a plain white page with “404 Not Found” text, not a branded page.
I will wait 2-4 hours for propagation and then check again.
My InfinityFree username is: if0_43064054
Thank you for help with SSL article, I will install it after 404 is fixed.
I simplified your message because we are recently trying to streamline support requests to help everyone better.
Your domain does not work because, in fact, it is not using our nameservers. Your domain is still using the registrar’s servers.
Now if you want to use 3rd party nameservers that’s fine, but you need to setup the records correctly. And for some reasons, your domain has several A records pointing at Google.
You should not have the records I’ve crossed out. And because your domains is not pointing to us correctly, we cannot help you, and you’ll want to talk to Whogohost instead.
