404 error in website (need help)
https://jenishachand.com.np
404 not found
I deleted and re-added my domain. I created the domain folder with htdocs inside it and uploaded index.html, but I still get 404. DNS and IP are correct (checked on dnschecker.org). I’ve been trying to fix this for 2 days. Please check my account and tell me what’s wrong.
Your domain is on your account, so this is probably a mismatch between the folder the domain points to and the folder you uploaded to.
The knowledge base article on 404 errors says every URL on a domain redirects to a 404 page if the domain’s website folder doesn’t exist on the account. It also says the files must be uploaded to that folder. So the folder name has to match exactly, and the htdocs folder with index.html has to be inside it.
You can check this in the Domains page of your members area, where each domain is listed with the folder it’s linked to. Can you tell me what folder name it shows for jenishachand.com.np, and what the folder you created in the File Manager or FTP is called? Spelling and capitalisation both matter, because the servers are case sensitive.
Here’s the article:
I’m getting a 403 when i visit your site:
and the fix for that is displayed directly on the page
