403 "Forbidden" error despite not using "include/require?"
epiz_32901841
403 Forbidden
Server or website configuration is blocking you from viewing this page
For a bit of context: I am getting this error upon clicking a hyperlink in my site that is meant to delete data from a table in a PHP Database. in my deletion script, I did not use any chat scripts, nor did i use include or require, so i am unsure as to why this is not working.
If needed, I can post my code in a follow up reply.
Are you able to ftp to your hosting account using Filezilla?
Yes, I am able to connect to my database just fine now, but I think it might be something up with my code.
For reference: here is my “delete from database” code:
<html>
<body>
        $servername = "sql200.epizy.com";
        $username = "epiz_32901841";
        $password = "Password";
        $dbname = "epiz_32901841_database2";
        $db = new mysqli($servername, $username, $password, $dbname);
        if ($db->connect_error)
            die("Connection failed: " . $db->connect_error);
$gameid=$_GET['rn'];
$query = "DELETE FROM titles WHERE gameid = '$gameid'";
$result=mysqli_query($db,$query);
if ($result)
    echo "Game deleted from the database!";
else
    echo "Game not deleted. Please try again."
</body>
</html>
It seems you’ve accidentally included your password in this file, please delete it and ensure it’s been changed.
“include” and IIRC “require” are keywords that will always return a 403 in the browser, but will work correctly if included or required from another file, not in those directories.
See this:
