I’m experiencing a 403 Access Denied error on all new posts and pages published on my WordPress website hosted on InfinityFree. The homepage and older posts (published before the issue began) are working fine. This problem started recently and was not occurring until around two days ago.
My Setup and Recent Changes
Hosting: InfinityFree (Custom domain in use)
Website type: WordPress
Previously migrated my site from the default free InfinityFree domain to my custom domain using the WPvivid plugin (which I later deleted after the migration)
Switched from All in One SEO to Yoast SEO
Installed W3 Total Cache and Autoptimize recently, then uninstalled both after the error began
Using pretty permalinks (e.g., /sample-post/)
Troubleshooting I’ve Already Tried
Disabled all WordPress plugins
Switched to a default WordPress theme (Twenty Twenty-Four)
Deleted .htaccess, regenerated from Settings > Permalinks
Tried modifying .htaccess to a default safe version:
Checked and corrected file and folder permissions (644 for files, 755 for folders)
Tried accessing from different browsers, incognito mode
Cleared Cloudflare cache and browser cache
Searched for and removed any extra .htaccess files in subfolders like /wp-content/ or /plugins/
Attempted to increase PHP memory limit and execution time
Confirmed I did not proceed with the Site.Pro website builder after seeing the warning:
Please help me figure out what’s triggering this 403 error on new content. I’ve done extensive troubleshooting and would appreciate it if you could check:
If ModSecurity is blocking certain requests or URLs
If server rules (e.g., .htaccess, index file conflicts) are affecting new pages
If any InfinityFree-level restrictions are involved (e.g., word filters in URLs or post content)
Let me know if you need access details or logs — I’m happy to provide whatever’s needed to solve this.
Would you mind sharing an example of a post URL that does work and one which doesn’t work? The two posts I found I could access. It would be a lot easier if we could just see the problem for ourselves, instead of having to hunt for posts that may not work.
I’m still new to WordPress and hosting, so I’m learning as I go. I’ve only published two posts so far, and both of them were working fine. However, when I recently published my third post, I noticed that trying to open the post URL gives a 403 Access Denied error.
The issue seems to happen only with newly published posts on my custom domain, while the older ones still open fine. I’ve tried deactivating all plugins, resetting .htaccess, and checking DNS, but the problem still persists.
Please let me know if you need any more info from my side.
Thank you so much for the suggestion!
Changing the slug from “chatgpt-vs-gemini” to “gpt-vs-gemini” instantly fixed the 403 error. I wouldn’t have figured out the issue without your help. I really appreciate the time you took to explain the problem and offer a clear solution.
Also, a big shoutout to the whole community here—this forum has been incredibly helpful for someone like me still learning the ropes. Thanks again for the support!
