I remember we learned C in third year and C++ in fourth year… But it’s better to use C++ because it simplifies some things.
I have noticed but some of the API that I want to use in future are written in c (and documented according to it)
Better to learn both then?
Start with C, proceed to C++.
what are you writing that it is not able to compile?
I would rather buy a desktop
because for the money you pay for a laptop, you can have a stronger desktop + large monitor
and of course, upgrade the hardware while with a laptop it is not easy
you just had to share my tests ![]()
It doesn’t do really well with my current pc for some reason. (It was back to when I had Win 7 so I’d glady try again,)
Only if it was as easy as laptop when it comes to migrating (I gonna get it for college)
Women should not go to school/college !
They should submissively serve their husbands and prepare food
here’s a laptop for you ![]()
At most I will end up installing Linux on the fridge.
I’m on 104, so I’m good. Also 37 unread, nice
I can also see this tool in my sidebar so I suppose it is some customization tool for yourself only.
But the privilleged users should be able to save it globally ![]()
I’m curious to know if our @leaders have the ability to save globally…
I’m confused. What is this and where is it on the forum?
You are able to create your very own sections that is invisible to other users.
After observing Oxy’s screenshot carefully, I finally figured out that mods have the option to save globally ![]()
I believe
should be changed to
[OBSOLETE] How to get a custom domain from Freenom with SSL and CloudFlare
This is going obsolete as well
Leaders can’t change the title? I thought you could ![]()
Did I ever do that?
Well, no ![]()
Moderators are there for a reason…
