Since you’re moving my answers to the new topic, I’m gonna refer to the start of the new topic instead in my answers. Now you probably noticed my answers are “please read the start of the topic” and the such.
I am just consolidating all posts to one thread.
Less messy this way
Anyway I found a workaround to access the Control Panel in the meanwhile if someone still feels the need to access it: use http://panel.myownfreehost.net:2082/ to log in using username and password of the hosting account for a while until the Control Panel’s new server goes back up.
That means the reverse proxy for the panel is down, but the instance itself is still up. Either nice discovery or you used MOFH for a while ![]()
I didn’t use MOFH in a while, but since the API and the reseller panel are up, I thought: what if I used the reseller panel’s IP (and so panel.myownfreehost.net) port 2082 to log in to the Control Panel?
The Control Panel itself was in a different server than the reseller panel, so that server itself is down, but the instances present in the reseller panel’s IP are still up.
Let’s just hope and reseller panel can handle the load and not crash
Yeah…
For me it works fine though… Maybe they’re getting to work to bring it back using 185.27.134.254 as IP instead. So let’s wait and hope for the best ![]()
And that’s the best part of using Cloudflare to manage DNS records; it’s that Admin manages the records for infinityfree.com and puts the new IP in place of the old OVH one.
Yeah, so now if the Control Panel changes IP again that domain will take the new changes without even the need to change the records again!
Yep. Made some changes to make sure that if the control panel is rerouted again, it should no longer require any manual intervention to pick up the changes.
The reseller API still won’t handle API calls though, but there is no way to fix that from my end.
Yeah, that’s why you asked iFastNet for that.
I use it because somehow it turned out to be the most accurate and updated very quickly
and in the same window, I can check some other things, perform some other actions,
as well as add custom NS.
Many other services use cache (they don’t start the test again) and then once you do the test they show the same result for at least 24 hours, and that doesn’t suit us.
In addition it is easy to send a URL query (IF-tools), they don’t block iframes, there are no popup ads,
and so on.
That DigWeb white test screenshot fits well into the default white theme on the forum.
I also use the terminal in rare cases, but I don’t want to share screenshots and it’s safer to check “online” .
Bear Grylls just pees on his wound, so you can too ![]()
Get well soon ! and you better chase girls there than to work
I got my shot and I’m still alive!
I’m good for 5 years if I get a dirty wound, so that’s good!
What do you mean by that?
hunt local girls (seduce) rather than cutting parts of your body and receiving injections
https://www.farmersdatingapp.com/blog/how-to-date-a-country-girl/
Curious what do you mean? Unfortunately I can’t think of anything else other than what I have in mind lol.
Edit: I just realized, glad that it is related to farming.
I mean the skin (part of the body)
TWU22 probably has a few GFs there
he just lies to us about how he cultivates the land and works hard,
but in fact, he sleeps all day and seduces girls in the evening
he was probably trying to perform some stunt to impress girls so he got hurt
and he got a new hat for those occasions
