anyone want a server !
details
free -g
           total        used        free      shared  buff/cache   available
Mem:            1511        1151         366           0           5         360
Swap:              0           0           0
zpool list
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
rpool 460G 68.9G 391G - - 22% 14% 1.00x ONLINE -
tank 112T 32.8T 79.0T - - 30% 29% 1.00x ONLINE -
cat /proc/cpuinfo |grep MH
cpu MHz		: 2400.003
cpu MHz		: 2700.221
cpu MHz		: 2400.223
cpu MHz		: 2699.958
cpu MHz		: 2701.147
cpu MHz		: 2698.336
cpu MHz		: 2699.927
cpu MHz		: 2400.030
cpu MHz		: 2700.010
cpu MHz		: 2696.594
cpu MHz		: 2699.685
cpu MHz		: 2700.609
cpu MHz		: 2699.973
cpu MHz		: 2699.989
cpu MHz		: 2399.999
cpu MHz		: 2508.988
cpu MHz		: 2400.050
cpu MHz		: 2700.006
cpu MHz		: 2400.000
cpu MHz		: 2399.995
cpu MHz		: 2700.672
cpu MHz		: 3500.000
cpu MHz		: 2700.317
cpu MHz		: 2699.000
cpu MHz		: 3500.000
cpu MHz		: 2700.377
cpu MHz		: 2699.963
cpu MHz		: 2700.212
cpu MHz		: 2699.955
cpu MHz		: 3500.000
cpu MHz		: 2399.979
cpu MHz		: 2699.735
cpu MHz		: 2399.991
cpu MHz		: 2699.969
cpu MHz		: 2400.006
cpu MHz		: 2400.000
cpu MHz		: 2399.981
cpu MHz		: 2398.619
cpu MHz		: 3500.000
cpu MHz		: 2699.980
cpu MHz		: 2700.001
cpu MHz		: 2699.739
cpu MHz		: 2694.556
cpu MHz		: 2399.898
cpu MHz		: 2400.357
cpu MHz		: 3500.000
cpu MHz		: 3500.000
cpu MHz		: 2700.043
cpu MHz		: 2400.001
cpu MHz		: 2699.968
cpu MHz		: 2700.281
cpu MHz		: 3500.000
cpu MHz		: 2400.259
cpu MHz		: 2699.960
cpu MHz		: 2699.640
cpu MHz		: 2399.777
cpu MHz		: 2400.023
cpu MHz		: 2699.982
cpu MHz		: 2400.035
cpu MHz		: 2699.966
cpu MHz		: 2700.030
cpu MHz		: 2699.647
cpu MHz		: 2700.037
cpu MHz		: 2400.000
cpu MHz		: 2700.629
cpu MHz		: 2700.996
cpu MHz		: 2700.134
cpu MHz		: 2700.009
cpu MHz		: 2700.578
cpu MHz		: 2700.152
cpu MHz		: 2400.162
cpu MHz		: 2699.949
cpu MHz		: 2400.487
cpu MHz		: 2699.862
cpu MHz		: 2400.031
cpu MHz		: 2399.997
cpu MHz		: 2698.290
cpu MHz		: 2400.002
cpu MHz		: 2699.971
cpu MHz		: 2699.119
cpu MHz		: 2700.018
cpu MHz		: 2699.836
cpu MHz		: 2700.180
cpu MHz		: 2699.994
cpu MHz		: 2699.664
cpu MHz		: 2699.987
cpu MHz		: 2399.921
cpu MHz		: 2698.219
cpu MHz		: 2400.047
cpu MHz		: 2699.985
cpu MHz		: 2401.273
cpu MHz		: 2400.031
cpu MHz		: 2400.014
cpu MHz		: 2399.984
cpu MHz		: 2699.983
cpu MHz		: 2699.984
cpu MHz		: 2699.983
cpu MHz		: 2699.652
cpu MHz		: 2700.056
cpu MHz		: 2400.013
cpu MHz		: 2400.104
cpu MHz		: 2699.174
cpu MHz		: 2699.499
cpu MHz		: 2699.745
cpu MHz		: 2399.998
cpu MHz		: 2699.882
cpu MHz		: 2699.959
cpu MHz		: 2700.001
cpu MHz		: 3500.000
cpu MHz		: 2699.959
cpu MHz		: 3500.000
cpu MHz		: 2400.000
yea sure gimme some
That’s a lot of CPU cores. I want please :slight_smile:
Only 112 cores, and 1.5tb of ram, 112 tb of nvme storage and 8 x h200 gpus
That’s a lot of ram in this fine economy, sir :frowning_with_open_mouth:
May I take the server?:face_in_clouds:
You want the gpus too?
If you can, that is!
I actually have an iFastNet account :laughing:
Forgot when did I sign up, but any ways, I don’t have anything in that account
OK apparently I have an iFastNet support account as well
Now what on earth is this
I was just reading documentation about WHMCS affiliate links and I saw this :up_arrow:
created my own lab server yey now i can giv people on the internet free vps server for 4 hours and they will definally use it to mine bitcoin and ddos and i have no idea how to prevent it XD
jk it is just random labengine lab server i found online and i connect it with my domain, found like 20 of them
To be fair, WHMCS is a black box that’s horrible to run. They design their software so you can just chuck it on a cPanel account, but god forbid that you actually want to host it in a proper, highly available setup.
So having the option to throw the management of WHMCS over the fence is quite an enticing idea.
Many companies that develop software are switching to a SaaS model, simply because you don’t have to deal with oddities from customer setups. Only big enterprises typically get self hosting options due to compliance requirements, but that usually costs big $$$$$, so that helps to offset it.
OMG
:thinking:
no it isnt it just your skill sucks, whmcs is like wordpress that provide the base system and your job is to modify it better to fit your case
Personally, I find it no where near as user friendly as Wordpress…
That’s quite a strong claim. I’d be interested to hear more about what you mean, because the challenges I ran into were pretty specific to WHMCS’s design decisions.
Every system I maintain is setup automatically. If a server burns down, I want to be able to replace it in 10 minutes, and have it setup exactly as the previous server was setup. With as few manual steps as possible, because manual steps take time and introduce risk of config diversion. I don’t want to manually download files, copy them to servers, extract them and manually run installers.
I mainly used virtual servers managed with Salt at the time.
But here WHMCS makes a few things difficult:
  • Their software is locked behind a login screen, making it hard to download automatically. You basically need to redistribute it yourself.
  • Programmatically installing IonCube Loaders isn’t pretty.
  • WHMCS locks their licenses to IP addresses, which means you need to reissue them if you switch servers.
  • And if you want to install WHMCS in a Docker container, this becomes even worse, because every time you update the Docker container, the IP address changes.
  • A very strong reliance on the local file system for file storage, which means you need to back this up and sync it, or use a networked file system.
The local file system reliance and IP locking are deliberate design decisions by the WHMCS developers that make it very hard to run redundantly across multiple servers.
I was unable to do it at the time, but I’m more experienced now, so I think I’d have a better shot. Still, it would take a lot of effort to work around WHMCS’ deliberate restrictions, hence my point.
If you say that my skill sucks, would you mind sharing what your highly-skilled setup looks like?
I agree with you there. In the sense that it’s also rather hostile to containerized deployments. But at least with WordPress, you can use something like Roots Bedrock which has a much cleaner separation between application code and data. No such luck with WHMCS though.
Except that the WHMCS source code is encrypted with IonCube, meaning you cannot see it or modify it. Yes, they support addons, but their addon API is too limited to solve basically any issue I had with it. WordPress plugins are far more powerful I think (although I must admit I’ve never created a WordPress plugin or WHMCS addon).
So:
  • “black box” = IonCube encrypted source
  • “horrible to run” = see above
@Admin Just curious, what would be your username if not “Admin”?
RICH
I thought you’re rich :sad_but_relieved_face:
Epic !
For a good reason.
iFastNet is slow for me :face_with_tongue:
I tried playing Genshin Impact (again) and my mind is blowing up, almost died when doing daily
I literarily missed more than 2 years of content and I can just no longer comprehend what is what
ohhhh license… my bad i didnt know people actually paying for whmcs
what? why? bruh like why?
im using old whmcs version (for obvious reason…yk) and so far i have no problem with it, i use it on just a regular cpanel solo server and definally not docker or random thing that make the solution become a problem, yes it is quite limited but with addon (and maybe a custom code to handle the thing that whmcs cant), it is basically wordpress for cloud seller.
ioncube is sucks, yes but why you want to modify deep into the code? i dont see the benefit of it than creating your own addon and add your own feature from it
for server backup, to be honest with you, i only backup the sql, 99,99969% i dont care about the source code because it only handle to read and write the database and talk with api and nothing more, there is no customer data saved on the file server, only sql data
if you want, you can use some tool to decrypt ioncube, recommend you to use old whmcs to get a better result
maybe whmcs is not for everyone, you want a solution from a paid product and you also want it to not get encrypt to modify it on your own, so if that the case then whmcs would be one of the easiest product to crack and the company wont get any money at all, and the support policy will be almost impossible for you to get benefit from it, for example you modify the code and you fked up some stuff and you want support, where do you find people to get help? ofc chatgpt, because whmcs wont support you to fix your modified code in any way (except it is addon i assume, i dont read policy)
you just make stuff too complicated for no reason, i still dont get the point of using docker to run whmcs, like why dont you just use cpanel solo? it is so easy to use and dont require complicated code to run, and beside that you can get support if things go wrong
save money is good but when you go to heaven, money dont go with you so just spend it when you can and save your valuable time for other stuff, not spending all of it to do the thing that no one do
(just saying no offense)
Not everyone is easy with cracking software
And you absolutely don’t want cracked software when you are running a real business
Benefits of Docker shows up when you are running a huge amount of servers and building a cluster. cPanel on the other hand feels more like a toy on this extent.
