sorry youre right i shouldnt have done that without a warning, I assumed people would realize it was a scam and that was a bad mistake
Spending time outside social media (including Discord) and instead, learning something that I enjoy and coding feels good.
@KangJL why are you selling your domain ?
I would be rich if this domain belongs to me
:joy:
Asked AI for the SVG code for a settings icon today to preface the word “Settings” in a button (ChatGPT was open, FontAwesome was not), and this is what it came up with:
Anyone have an idea of what that could be?
A gear from a car transmission that someone forgot to fill with transmission fluid?
it looks like a punk sheep to me
do you know where can I find this new user tutorial mentioned in badges ? thanks
You’ll find it in your private messages on a private topic named “Greetings!” created by discobot, I think.
Alternatively, if for some reason you cannot find where the message is, use
@discobot start tutorial
for tutorial (Certified) and
@discobot start advanced tutorial
for advanced tutorial (Licensed).
Make sure to have disabled “Skip new user onboarding tips and badges” in Preferences > Interface. (Oh, and you can request the message again from here too.)
Like a, um, molten settings icon? I don’t know…
Thanks guys :+1:
oo pretty :smiley:
I’ve run into a slight problem with the
when it asks
Go ahead and delete any of your posts above by using the delete action. Don’t delete the first post, though!
I’m unable to proceed as I don’t have any way to delete a post as there is no trash can visible
Any ideas ?
You can skip some parts of the advanced tutorial by typing skip; for the second time you skip the tutorial, so when it tells you to undo the deletion, you can type @discobot skip if it tells you that the message body is too similar to the one you wrote before.
i’ll try thanks
it seems like its not possible to do the advanced tutorial, I can skip the delete post but then the next step is to undelete the post which isnt possible
but if I also skip the undelete post step then the tutorial quits and doesnt allow to continue
does anyone follow cricket here?
Not me
Also http://epicdb.org | CF error page on root domain, lovely :smiley:
Deep fried or plain?
