Maybe this?
Late thanks ^^
Since I have a DirectAdmin hosting account thanks to @anon86539743 ![]()
One of the features I have is custom email address. But sad realization that IF client area thinks my custom email is a disposable one ![]()
How my custom email under lauraorchid.my.id is automatically assumed as disposable? Is the address checker on whitelist mode instead of blacklist ![]()
I think they are just a player but doesnt do the actual decoding
I need one where the mp3 decoding and re-creation of the sound using sinewaves is done in the javascript as it is this part I will be experimenting with
Thanks
Thatâs cool! Why are your Y and Z keys swapped?
Now I have a doubt to get solved.
After someone shared their hosting account credentials to everybody to see in this forum in the hope to solve the problem with their database connection for example (with someone that is a Leader or a moderator unlisting it in the meanwhile), then someone that manages the system (so only the Admin) decides to reset it after some time and, in the meanwhile, before the reset, the one who did that mistake edited the text to not include for example the password, but a moderator didnât hide the edits history for the post that included the old password, is it safe to list the topic again or still not? Because I think I made a mistake⌠And itâs also my first time doing it on a topic that included those dataâŚ
Personally, I would wait until that edit is resolved, but if itâs reset then I donât think itâs too much of an issue. The only problem I can think of is if the password reset takes a little bit to kick in, but it shouldnât.
I (personally) would just like to wait to keep a rigid routine (unlist the post until password is reset and/or edits made to hide the credentials).
OK, got it.
I could have waited as well, but it was my first time listing a topic that was previously unlisted for sensitive detailsâŚ
If the password is reset, it should immediately be safe to relist. A moderator removing the password also works, but the password should be reset by someone if it was shared publicly.
Got it. With this answer, my doubt is now finally cleared!
Hi again ![]()
the collective noun for a group of baboons is a troop
but I think it should be a pentagon of baboons
Hello!
Fun fact, my countryâs ccTLD variant of .my.id only costs $1 for first year, and $2 for renewal. So no more headache on custom domain ![]()
My countryâs ccTLD, .cn, alongside with other variants, are all dirt cheap but all have a really bad reputation for ceasing your domain whenever they want.
So itâs still headache for me ![]()
I just configured Cloudflare to initiate a challenge for all User Agents that does not have Mozilla/5.0 in it and succeeded in breaking my site. (SSO stuffs requires communication between sites and the client doesnât put Mozilla/5.0 in its User Agent.) ![]()
Never play with Cloudflare when you donât know what the h*ll you are doing.
By the way right after setting up the rule I saw I recieved like 20 requests from China that have a weird UA. Donât know what it is and donât care ![]()
I found a wallpaper that I like
but the colors didnât match with my current keyboard color settings
so I changed the colors of the picture to âindigoâ and adjusted the colors from amd adrenalin overlay to match the colors from the wallpaper
In the dark it is indescribable to look at the monitor because it is 90cm (horizontal <---> ) and covers the entire field of vision
It took me three days to get used to the curved screen, but itâs much more natural and suits me perfectly now
and it is much better than having two or three âsmallerâ monitors
and I forgot to say that I moved the start to the middle
less mouse movement and makes more sense on ultrawide
I was made aware that March 14th is the day for something else too but too inappropriate to be said on this forum ![]()
