I believe it should be the AX72
https://www.amazon.sg/TP-Link-AX72-Dual-Band-Gigabit-Archer/dp/B09BMLJ9YD
@anon90933456 we have another update - https://www.amd.com/en/support/chipsets/amd-socket-am4/b550
after installation remember to click
Screenshot 2024-02-13 124335
to see if everything is OK
I had a FAIL for cpu power…blah blah
but as far as I can see online it’s normal because my cpu doesn’t even use it.
I’ll update the chipset driver when I’m at home, as now I’m coming back home!
if amd Adrenalin can’t print cpu freq and temp in stats/overlay
then you reinstall (repair) amd adrenalin and after restart it should be ok
I updated the chipset drivers; now it’s time for a reboot and a check if AMD Software: Adrenalin can print my CPU frequency and temperature. If not I’ll reinstall it!
EDIT: Now I’m also updating AMD Software: Adrenalin. For now everything is working fine.
I have several task/services killed because I don’t need them
so maybe that’s why it’s not able to retrieve cpu stats
or all simply need to go in a certain order… first chipset then adrenalin… and not the other way around.
Good news!!!
Weee - congratulations !
did NS remain as they were before or did you have to do it again?
Yes, but I am not so sure it will be good for 9 years…
if they return it to you and not to me, then I will go crazy :joy:
I am sure you will get the domains back online.
It’s just a matter of time, due to overwhelming number of emails received by Freenom
it’s a success to extend it for 1 year - because if I hadn’t dug Reddit, I wouldn’t have even known that someone had tried to solve the matter by email and I would have forgotten about those freenom domains right away.
I don’t know… my was on Cloudflare NS etc. + and they all have redirection on .com…
they might find it suspicious
It was the same for me. Otherwise you would have received this CloudFlare notification
did you thank them via RE or not?
I just did. Important to show gratitude!!
Sad…
I forgot to tell you that since the last version of Adrenalin
the overlay remains standing even after the restart.. if you remember that I complained before that it would be great if it was put in the startup and that I don’t have to turn it on manually every time..
and now there is the possibility of choosing colors for the titles as well as for the values.
I don’t know how often you turn on your gaming PC, so I don’t know when was the last time you made an update for adrenalin.
sorry if you already knew that :smile:
i was amazed how well this runs in a browser on my basic laptop with intel gpu on cpu :smiley:
http://xproger.info/projects/OpenLara/
Small increase (Cloudflare monthly report) :upside_down_face:
btw. 10k is open for 24 hours so you can write some love messages there (or anything you can think of)
Screenshot 2024-02-15 182507
:scream_cat:
Screenshot 2024-02-15 181402
