It’s a bit weird because with bulk actions it gives you the “Set Category” option:
But, I’ve tried it before and it doesn’t do anything.
And the same goes for setting a timer. As far as I’ve tried you can only auto-close a topic if you choose “after the last reply”. If you try to set a fixed amount of days it doesn’t work.
But what happens if a post was made one minute ago and you saw sensitive details and you make it a wiki to edit it, would it still show the revision?
That’s probably because the action is blocked to you as a leader, yet the UI option is still there for some reason. Weird.
Probably, yes, since the edit was done by a different user then the one who created the post.
Hi this is a test - YT
Yes, it would. And what I saw before was the proof!
I :heart: logs!
Don’t ask why I view logs in notepad
WTF is this?
http://archive.hack.lu/2017/hacklu-crypto-api.pdf
Why not use Notepad++ ??
Nah. VSCode is superior :sunglasses:
(Especially for me as Notepad++ once expressed hostility to China. Some started to boycott it ever since.)
I was forced to use that on a managed machine in time, and it sucks! Maybe that’s just because I’m not used to it, but it seemed to be like a glorified text editor from when GUIs first started appearing. (Fine, a bit harsh, but the interface was :nauseated_face:)
I like Sublime the best for actual coding/programming, but use notepad for reading log files and such (Mostly because I have the line height on Sublime set pretty skinny, so it can be hard to read multi-line errors/logs).
And there, you have the reason :slight_smile:
VSCode takes forever to update, and forever to open. I use it for the little bit of C# and on-machine Java I do, but that’s it.
You sure that isn’t a computer problem? I have 4GB of RAM and I can open it relatively fast.
I don’t think it’s the computer, and it is for sure not RAM. I have 32gb of it.
Well, then, I am not sure why it takes so long for you. VSCode is lightweight.
Wait … which one are we talking about?
I thought that Visual Studio and VSCode were the same thing, they are not?
This is what I have:
Indeed they aren’t; VSCode (or as most people call it Visual Studio Code) loads faster, even with an SSD installed!
Oh, I see, you thought they were the same. Visual Studio does take a while to load and update. But as JxstErg said:
Visual Studio is like Unity for applications using C#, C++, and other things like ASP.NET. While Visual Studio Code is just the code editor. VSCode is a lot more customizable and user-friendly. It has a bunch of extensions and things of that sort.
In my experience VsCodium is way faster, but with limitations.
X also.
Concerning “”" [quote=“Oxy, post:3538, topic:75660”]
You have to be careful what you say because when AI (machines) rule the world then they will go and see who wrote what
[/quote]
Jammed with trigger vids now.
I hate to say this, but if you were to go with such logic then you may as well ditch most of things. Some of the programmers behind VSC may as well have xenophobic tendacies towards your race but you are unaware about it.
People should learn to keep their opinions away from their projects especially when it is open source, even then sometimes you need to “separate the art from the artist”.
Yeah I guess People come to forum to solve their problems.
Anyways, thanx for your help and keep up the good work,
I have to say that sometimes it is the difference of being awared or unawared. Sometimes it is the difference of if it is some contributors or it is the main developer.
These psychologically gives you different feeling, and that’s all.
I personally don’t wanna go for such logic, I mentioned it just because of I thought it was worth mentioning.
