I abbreviate it so it is not advertisement I can DM you the URL if you want.
So I changed how the password reset system worked last year to get rid of a potential security vulnerability (Which was probably more paranoia then an actual vulnerability), and did not update the 2FA Auth system. So the new password reset code was not getting sent to the Auth service correctly. First fix was the main one, getting the code to the Auth system. Fix 2 and 3 was me forgetting how PHP functions and the āincludeā command work.
Once I figured out what was causing the issue, it was an easy fix (annoying and time consuming though). Overall, it could have been way worse!
It was probably more the fact that it was task manager running inside a util account (Notice the 66% memory in the util account, the primary windows memory usage was only 22%). My primary windows TM instance was running the entire time and never faltered.
But Win 11 does very much have downfalls (Explorer is worse, and its really annoying)
Was playing Arma 3 and going through a little situation I put myself into (air combat).
I died a few times because the enemy would deploy countermeasures and my AA wouldnāt hit, leading them to fire a barrage of missiles themselves and take me out. I played again and got a lock on one of the planes. Thought it would be funny to ask Bing what I should doā¦
(Itās edited because I copy-pasted my convo into a new one and tweaked a few things for more accuracy)
Please note that the use of missiles is a serious matter
No joking
I love how the AI just rolls with it. Maybe itās been trained on enough internet data to handle trolls? One of the sources it pulled was for a flight simulator game. If I slightly edit my responses, it either says that violence is not the way to go or that it canāt discuss military stuff.
I actually have before (about 2mo ago most recently). Really the only reason Iām still on Windows is that MS Office suite isnt available for Linux and it doesnāt run on Wine (at least it didnāt last time I tried it). Iāve set up arch a few times in a VM before and it is painful but not too hard once I got the hang of it (for that specific computer at least, lol).
Iāve only tried Manjaro, but I like it and have heard good things about it. Iāve never heard of the other two you mentioned so I guess itās time to do some research!
This would solve my Office problem! Especially if I use something like Tiny11 then it might be a feasible solution.
This. The only thing good about it is the tabs, which plenty of other file managers have had for years. Pathetic on MSās end if you ask me
Well goodnight yall I canāt miss my alarm tomorrow morning and I am super tired
put a tick here
so that if any device does not respond on time
because the explorer tries to display the file size and current state (refresh often)
does not freeze
e.g. when you transfer files from a mobile phone and the like where the mobile phone often does not respond to queries or refuses if it is about two or three folders
it does not freeze the whole explorer, but only that instance.
And then, if necessary, just type explorer.exe under run in the task manager.
I still have 100/20 with FTTC, at least for now⦠But when my ISP finishes works for pure fiberoptics, my modem is ready because all I need is an ONT; I already remember the credentials to connect to the network, so Iāll configure my modem as a router, connect the ONT to my WAN port, connect to the Internet with the credentials and Iām ready to go!
