i know.
This’ll be fun to clean up
Super nice advice that I almost think it’s a sarcasm ![]()
Anyway the IP 185.27.134.114 is up again, along with the others in that problem, but seems like another IP is added to the problem: the one ending with .123. I’m getting back to sleep now!
thanks anyway …but I changed the IP
that didn’t help either !!
I have 403 on ex IP .176
and on the new IP .112
I have the same as the GR9 on his website
everything is white and the source code is
because me and GR9 have on CF rule for aes.js
and when I remove the rule, it immediately flies to i=3 and I see google page regarding cookies
I’ve reached my daily like limit, but I’m gonna sleep again after this reply, so it’s not important!
Anyway seems like Cloudflare with free hosting isn’t working as it should; did they forget to whitelist on their nginx test cookie module Cloudflare’s IPs?
So they forget to while list CloudFlare to make sure the JS challenge bypassed for websites using it? I’m confused.
They did, but strangely enough a website that uses Cloudflare on free hosting worked for me without redirect to the cookie page, so Cloudflare and nginx with the testcookie module could work out for some browsers I think?
I want them with milk!
They just forgot to renew the certificate, but seems like Arc also uses HSTS, so for now you can’t access the website until they renew the certificate…
But anyway Arc is (or was) paying out well!
Let’s give it a week. If it stays the same, then we know it’s dead.
If you look at past history, SSL was normally renewed about 30 days before time is up.
Not this time. That was why I had a bad feeling about it
Oh…
A well-deserved follow-up I guess as well!
Is it for websites with CF or any sites on a specific IP?
So far I am seeing it on CF websites. If more users report, then we will know if non CF websites are affected as well
Hi KangJL,
Just wondering what is the last time you get a payout? The site is up and running after bypassing HSTS. I’m thinking whether I should give it a try.
Lmao, everything that supports webp is affected by it.
