oh ok. IG I’ll just try installing that instead. I assumed it was just an addon.
I’ll do it after I get back from work, I’m going to start at 1.
Soooo… uh… this is interesting.
Making zyn fusion just causes conflict with an already existing file.
Now, for some reason, it looks like this stuff belongs to Visual C++ (vcRuntimeMinimum files are in the users directory, and it looks like the file with my name is in cohorts with that, too).
What do I do? Replace the file? Will that mess something up?
Why does it even make this in the first place? It already reinstalled msys and clang when I installed the dependencies using this command:
The heck is going on?
Is there a way to change the output directory?
If not, then I would move the existing files into some temporary folder (on your desktop for example)
and then let Make either create the files (b/c you moved them) or overwrite them (b/c you copied them)
Other than that, I’m not sure as I’m not familiar with the library and I’d have to study and experiment with it for hours to give you any more useful answer.
Also, here’s a really interesting article about how UUIDv4 is “completely-unique” but not…
There’s a lot of math!
https://towardsdatascience.com/are-uuids-really-unique-57eb80fc2a87
That’s what I thought I should do, but at this point is it trying to rewrite my whole directory? lol (Ok, well it’s likely not. But I don’t know what it’s doing so it’s scary behavior which I don’t quite like)
or simply select a new pattern (which is not used)
press the REC button>rec all>and everything you touch in the DAW will be recorded in that pattern - literally everything
Hosting support getting busy…
Storage and home directory issue…
The only problem is that I’m using LMMS, not fl studio.
AHHHHH
I spent 20 minutes trying to figure out why my code was always returning the incorrect text.
This was my code:
if($stupidDumpVariable = "NONE'){
This was the right code:
if($stupidDumpVariable == "NONE'){
I really hate it how a single equal sign takes 20 minutes to fix.
Well, you’re also mixing double and single quotes lol…
Note to self:
If you are going to design a PCB that you are going to print a cover for, you should probably make sure the holes are evenly spaced so it is not a nightmare when designing the 3D file.
At least you don’t have to deal with resource files with the Win32 API.
So annoying…
hi everybody ![]()
How many login accounts do you have?
I have some previously, but those didn’t have any hosting accounts and i forgot the passwords for them.
Some ? ![]()
And a few more suspicious ones…
We suspended all but the last acc forever
Remember, 3 hosting accounts per PERSON.
She is a mystical intriguing person
a 17-year-old girl writes in BIO
and for those years it is strange that the emphasis is on “My little pony”
then on the other hand there are posts about linux, coding, etc., where it seems older
then she forgets passwords very often (every acc so far)
I wouldn’t say that she is malicious because she regularly appears here on the topic with every new acc and announces it to everyone. And to some extent, she follows a pattern (purple avatars mostly).
she has been with us for more than two years (25 badges and so on)
The only problem is that she changes accounts too often.
Looks like someone needs to get a password manager…
