“Well gang, it looks like we have another mystery on our hands.”
Learned some tricks from the toxic gaming community that I’ve been dying to try out ![]()
I don’t get it…
The screen is initially white, and you can lay down road which is a thick, grey line. The red are vehicles traveling on the road.
See if that that gives you the picture of what is going on.
somewhat…
Would be better if I could give you a video.
Basically, count your blessings.
you need to read cca 2k posts and 200 topics
cca?
I’m going to guess that was a typing mistake.
still don’t know what it is ![]()
I don’t either.
These are the basic requirements (Although Admin could have changed them).
To get to trust level 3, in the last 100 days…
Must have visited at least 50% of days
Must have replied to at least 10 different non-PM topics
Of topics created in the last 100 days, must have viewed 25% (capped at 500)
Of posts created in the last 100 days, must have read 25% (capped at 20k)
Must have received 20 likes, and given 30 likes.*
Must not have received more than 5 spam or offensive flags (with unique posts and unique users for each, confirmed by a moderator)
Must not have been suspended or silenced in the last 6 months
*These likes must be across a minimum number of different users (1/5 the number), across a minimum number of different days (1/4 the number). Likes cannot be from PMs.
@Oxy, you once shared a link here with a bunch of cool free images, would you find sharing it again? I can’t find it.
circa
Circa, which translates as “around” or “approximately,” usually appears with dates. You may see it abbreviated as c. or ca. (or, more rarely, as cca. or cir.). It indicates that a number or value is approximate, not exact. For example, you might see sentences like “the construction of Stonehenge began circa 3000 BCE.” More rarely, you may see circa in reference to measurements of amounts, such as “circa $45,000” or “c. 1.5 mL.” Your meaning will often be clearer to readers if you stick with English in the main body of your text and save “c.” for things in parentheses and notes. So, for example, you might write “the construction of Stonehenge began around 3000 BCE” or “when Stonehenge began to be constructed (c. 3000 BCE).”
open here dev tools and in the console at the bottom paste this code
window.setInterval(oxy, 10000);
oxy();
function oxy(){
window.scrollBy(0, -window.innerHeight);
and every 10 sec it will go up (as a page up button)
and when it’s over you will have I believe a couple of thousand posts read
increase these 10sec if necessary
I could prob do that with liking posts as well.
Would take a little bit for the messages to load, so ~3 secs would prob be the min limit.
Isent that cheating?
They might as well give up then cause trying to prevent manipulation of the client is impossible.
you have to see how long it takes the forum to remove that dot (css bullet) next to the unread post
it is not ! ![]()
it’s the official way to get thousands of posts the easy way
than spin the mouse wheel for 30 minutes ![]()
and then there are still 200 clicks left on the various topics
and he will become regular.
or you may be better going from the top > down ?
because I guess there are more posts you haven’t read
means scrooll at the beginning of this topic and then insert that code into the console,
but just remove the negative value
for -window.innerHeight
Yeah IK ![]()
