This site can’t be reached
My wp admin not opening and also site is not working getting following error please help -
Check if there is a typo in www.urinfopedia.com .
If spelling is correct, [try running Windows Network Diagnostics](javascript:diagnoseErrors()).
DNS_PROBE_FINISHED_NXDOMAIN
KangJL
July 16, 2021, 2:28am
2
My best guess is 185.27.134.33 is down. Have patience
NXDOMAIN means that the domain hasn’t been registered.
@Urinfop , please clear your DNS cache. If you’re on windows, go into command prompt and type ipconfig /flushdns
done nothing happen the site is down since last 7 days
your dns isnt setup to point to infinityfree.
should be
ns1.epizy.com and
ns2.epizy.com
not the right ip - infinityfree doesnt use hetnezer
You website I think works. It is just that it has no files:
system
Closed
July 23, 2021, 8:15pm
7
