Without www subdomain is not working
https://talvexglobal.infinityfree.io/
This site can’t be reached
talvexglobal.infinityfree.io took too long to respond.
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
with www is working but ssl not deduct how we can fixed ?
The article below says the www version of a free subdomain can’t have SSL, which explains the part you can see. It’s the non-www address that should be using HTTPS. The system-wide certificate covers direct subdomains like talvexglobal.infinityfree.io, but not www.talvexglobal.infinityfree.io. The article says the certificate is active the moment the subdomain is created, so there’s nothing to wait for or install.
Here’s the article:
That doesn’t explain why the non-www address times out, though. A certificate problem would normally show a security warning, not ERR_CONNECTION_TIMED_OUT, so I don’t think the certificate is the cause.
Two quick checks would help narrow it down:
  • Does http://talvexglobal.infinityfree.io/ (plain http, no “s”) load?
  • Does the https:// address still time out on another network, like mobile data, or on another device?
If it times out everywhere, a person will need to look at it. If it only fails on your connection, the cause is probably between you and the site.
Works for me, issue is probably on your end.
It’s working fine from here too. And I just checked your account was only a few hours old when you posted this.
So I’m pretty sure that this is just DNS caching, and the issue will resolve itself automatically after a day or two at most.
Next time, please make sure to check the Health Check in the members area for your domain. It actually tells you that your website may not work while it’s new, which is a broad bucket of issues, but that’s because the actual symptoms can be quite wide. This is definitely one of them though.
