Will I have trouble using the "Releasei - Better Search" plugin on my WordPress site?
This is the link of the “Releasei - Better Search” plugin:
And this is what caught my attention:
Do note that using Relevanssi may require large amounts (hundreds of megabytes) of database space (for a reasonable estimate, multiply the size of your wp_posts database table by three). If your hosting setup has a limited amount of space for database tables, using Relevanssi may cause problems. In those cases use of Relevanssi cannot be recommended.
There is not really a limit on the amount of space you can use on the database, but there is a limit on how often you can use it.
It’s worth a shot, and if you get suspended, then you know it won’t work here. Do note that your site may take even longer to load though.
Storage is mostly not an issue here, but the number of requests on each search to the database may lead to suspensions. Honestly, the plugin is heavy of sort.
