Why magento installation block when it i have 95% done
[epiz_26787985]
I cant finish the installation of magento in my infinity free account why
check if the folder where the installation will be done is empty
There are many reasons why Softaculous doesn’t work right away. Could you also try installing it manually and see if that works?
Although, looking at that documentation (and from personal experience), Magento is a EXTREMELY complex ecommerce solution with very heavy server demands to run. Very few hosting providers provide all the required server components to run Magento to it’s full ability.
If you just want to create an online store, Magento is massively overkill for the purpose, and there is more effective software that can serve that purpose.
