What Forums Theme does InfinityFree use
I wanna know which Theme InfinityFree uses for their Discourse Forum or what theme this is based on, i saw a forum which looked 1 to 1 like this so i knew this is some kind of theme
Looks like the default with a purple accent color
It’s just the default theme for Discourse with a few custom color palettes that match the rest of the InfinityFree branding.
Theming support is a bit limited with Discourse, and the default theme has enough options to make it fit the branding, especially once you add Theme Components, so there is little reason to go custom I think.
So I think You got the Message But I want to say something. I like this forum because of the simplicity and Categorizing and you know It’s Simple But fills the need. Respect
