so it still doesnt work on my pc even after resetting my network. but when using a vpn it works. i guess my IP is blocking it for some reason. it didnt do that before the deactivation. do you know how i can fix it?
Before I’m going to hunt for a block that might not exist, can you please clarify what exactly you see when you try to access your website? What is the exact behavior and/or error message you see?
Based on the error message provided in the screenshot, it’s most likely that your Internet Service Provider has blocked access to your websites. You will have to contact your ISP to resolve the issue.
