Website not working in Daytime
Website URL : https://wiredlens.is-best.net/
The website stays down in daytime while is working properly at night time.
I don’t know what can be the issue here as even the Wordpress admin panel isn’t working in daytime, IST (Indian Time).
And just for the information no my website isn’t new it has been published on 12th October 2024. Yes, it does have all the nameservers of Infinityfree, Yes it does have HTTPS (SSL). Yes, I have done proper configuration regarding DNS.
This site can’t be reached
wiredlens.is-best.net took too long to respond.
There isn’t any issue with the network or firewall settings as I have checked it multiple times and the website works perfectly at night. This wasn’t the issue before since last 3-4 days it is happening. Please help if anyone knows how to solve this issue. I tried contacting Infinityfree support as well they responded to create a forum for this issue
No issue for me
Issue is likely on your end.
Try vpn?
Website is functioning as expected. Website loaded at 8:05 AM
It did take a bit to load.
Yes, It did load as here it is night, and I tried using a VPN I used different networks and systems to check. The same issue is persistent. Please help if you know what the issue could be. There are no errors given to me on the WordPress dashboard.
I’ll report to you approx. 9PM where I am to see if it loads.
In India it is 10am in the morning and if I look at the website it Isn’t working with the same error along with VPN as well.
I am quite certain issue is on your end.
What does tracert show?
Well, it’s 12AM here …
It’s now 16:30 in IST, and your website is working from here.
I don’t know why you have this issue. Your website seems to be working perfectly 24/7. As for why it’s inaccessible to you, I have no idea. My best guess is a network issue or block on your end, but I don’t know, because I cannot look from inside your computer.
Admin, are you in Turkey?
No, I’m not in Turkey, why are you asking?
When I translated your message above into my language, it translated as 16:30 in Istanbul. That’s why I thought you were in Turkey.
He said IST, as in the time zone :slight_smile:
