Website not opening
https://www.pipelinesteam.rf.gd
website not opening. below error
This site can’t be reached
Check if there is a typo in pipelinesteam.rf.gd.
If spelling is correct, try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
Same error for both websites - pipelinesteam.rf.gd, apnatrade.rf.gd
Is the error the same on a different network, like mobile data, or with a VPN on? And what does nslookup pipelinesteam.rf.gd 8.8.8.8 return?
Your hosting account is active, and both pipelinesteam.rf.gd and apnatrade.rf.gd are attached to it. So this doesn’t look like a suspended or missing account. That makes me think the problem is in how the name resolves rather than in your site. The two checks should show whether it’s your network’s DNS or something wider.
A few other people have reported the same NXDOMAIN error on rf.gd sites. This one says it only worked for them over a VPN:
That might be the same thing, but none of those topics had an answer I could cite, so I can’t say what the cause is. If it works on another network or over a VPN, that points to your ISP’s DNS. If it fails everywhere, a person will need to look at it.
both seem to be working for me:
might be worth trying a VPN see if maybe your ISP is blocking the rf.gd domain
Yesterday it worked, Now it is not working and same error is again shown
Have you tried a VPN or a device on a different network yet?
