Website not coming up on mobile devices
https://smefinancepro.com
Hi,
Although i am able to view my site on my laptop, however, I am not able to view it on my mobile devices (android phones).
I have also tried using Cellular Data, but it still doesn’t work on both cellular data & wifi on my mobile devices.
Can somebody kindly help please.
Thank you
Kind regards
Welcome to the forum.
It’s coming up fine on my mobile:
This would suggest that the problem isn’t hosting site.
It’s possible that your mobile provider is blocking the site?
Can you share a screenshot of the screen you’re seeing?
Thank you very much for getting back to me.
Basically from my end it says: This site can’t be reached. Check if there is a typo in smefinancepro.com.
Is there a way to know if my mobile provider is blocking the site please?
UPDATE: I just realised if i use a VPN i am able to connect on my mobile!
You could ask them. Thats the most reliable way
that supports your mobile provider blocking the site
When did you add the domain? If it’s less than 72 hours ago, it might just be DNS caching and solve itself over time. A VPN usually overwrites your DNS settings as well, so your ISP or router may have old cache data, but the VPN provider’s DNS resolvers might not.
Thank you very much for your advices…
Actually it’s been more than 72 hours, but right now i just added the domain to Cloudflare cdn to try and resolve this issue. I will let you know if this actually resolved the issue.
