Website inaccessible – ERR_CONNECTION_RESET despite active account
https://espacepedagogique.kesug.com
Sometimes ERR_TIMED_OUT.
The website cannot be reached from my computer or my phone using mobile data.
My hosting account status is Active.
The website files are present in /htdocs, including index.php, config.php, test.html, and test.php. I checked the .htaccess file, and it does not contain HTTPS redirection rules.
The website remains inaccessible from both my computer and my phone using mobile data. I have not deleted or replaced any project files.
Please investigate the server and domain configuration. Thank you.
I think the first step is to run the check-host test from this article, because it shows whether the problem is only on your side.
Why can’t I connect to my website?
Enter https://espacepedagogique.kesug.com at check-host.net and click HTTP. Then tell me whether most locations show OK or fail. If most are OK, the site is up and something is blocking your connection to it. If most fail, the problem is on the server side, and a person would need to look at it.
You’ve already tried your computer and your phone on mobile data. The article says that if the site works from another connection or a VPN, the block is tied to your network or IP address. So it would also help to know:
  • Does http:// (typed in full, not https://) behave any differently from https://?
  • Does the site open through a VPN?
Your account being Active and your files being in htdocs isn’t the issue here. This error means the browser couldn’t connect to the server at all, so your site’s files and .htaccess never come into play.
There was this topic from a few days ago which I think is related. The person posting it was also from Algeria and was also using a kesug.com domain. We concluded there that it was probably an ISP level block. And since you’re now reporting the same, that only supports that theory.
Since the block seems to focus on the kesug.com domain, you could consider migrating your website to a subdomain on a different domain. However, I cannot guarantee that any other domain you choose won’t also get blocked, because this is the unfortunately reality of free subdomains. The best way to eliminate the issue is to buy your own domain name instead.
