### Website URL
Hi, some month ago I made this site using wp. Today it seems it has disappear…where can I restore it?
thanks
Herbert
2
Works fine for me, are you asking about what happened to your content?
Oxy
3
@marco1243 Hi and welcome to the forum
In general, you should have some form of backup
hi, thank you, but the entire wp installation seems to be erased from the account. Do you know why something similar could be happened?
Herbert
5
If you haven’t used your account, they might delete it.
I think this article might help you.
Your site is on the IP Address 185.27.134.116
, so depending on when you were last active, in August there was an outage that resulted in file loss:
If you have a backup, you can restore from there, otherwise your installation is sadly gone.
lovebug
7
Did you re-install wordpress ? I see this
system
Closed
8
