Website build advice please
I have a website already published but thinking about maybe redoing using wordpress.
I see i can install wordpress via softaculous. If i do that do i lose my current already loaded website or does it remain until such time a hit publish in wordpress.
Thanks
Correct.
WordPress can be installed in a subdirectory and does not have to be on the root
so it probably won’t overwrite the existing page.
But if you don’t know what you are doing then it is better not to touch it :slight_smile:
Each user can have 3 hosting acc
so I suggest you activate another hosting acc through the Client Area
and then you choose one of the free subdomains
and there you install WordPress and experiment and learn along the way.
If you are satisfied with your product (website), you can easily copy it to your original domain/address.
Good idea hadnt thought of that
