Webmail Not Working
Hi,
Webmail is currently not working.
This is the error message:
DATABASE ERROR: CONNECTION FAILED!
Unable to connect to the database!
Please contact your server-administrator.
What webmail were you using? Your installation or the one on http://185.27.134.244/roundcubemail/? Because if it’s the former, you may need to initialize the database for it to work, and set up your mail server or use other ones; if it’s the latter, you will need to wait until it works again.
If you were using http://185.27.134.244/roundcubemail/, then iFastNet has fixed it and it is working again.
