Web is not accessible from my ip
Hello, My website (sigmaware.fun) is not accessible from my home network, but it works perfectly when I use a VPN. It seems like my public IP address is being blocked by the server or firewall. When i try to open the site from my ip it says "Connection Timed Out The server at "sigmaware.fun took too long to respond. Can assure its not device , user-agent (browser), or ad-block(or other plugins) issue as i tested in on many devices in my lan returning the same error.
Mabye is your isp blocking the ip
Try clearing cache or using a different browser.
It seems like your downloadable files are hosted on your website. Please note that it is not allowed to do so and you could better use a file sharing service instead.
i found out that the web does not work on multiple ips, so i this isp isn’t the issue.
not the issue bud
It might not be the issue but you are still breaking the Terms of Service, “bud”.
You agree to not use the Services to:
~snip~
upload, post, email, transmit or otherwise make available any material that is of keylogging / proxy service / irc / shell(s) if any type / file hosting / file sharing types.
I’ve seen this error before when my phone script accidentally dropped into an infinite loop or took over 60 seconds to complete.
Both of these are worth checking
