Using IMAP in osTicket
Hi, I have installed osTicket through softaculous on tech.tquinn.cf
It all works fine until I go into admin panel → email → edit email and put in my IMAP details to automatically create tickets: it says IMAP doesn't exist. PHP must be compiled with IMAP enabled
Would you be able to enable IMAP on my account’s php? I can’t see a way to enable it myself.
Thanks,
– Tom
Sorry, but in order for fairness, they can’t unless everybody receives IMAP. Plus the mail system been disabled for spam issues.
Odd, I can remember it being enabled in the past and can’t personally thing of any reason why it would be disabled. I’ll go check if or why it was disabled since then.
EDIT: I just received confirmation that IMAP was disabled on purpose due to abuse. Unfortunately, that means you cannot use IMAP on free hosting, and you’ll need to upgrade to premium to use PHP IMAP functions.
