Using CNAME to verify domain
I waited after adding cname and it still won’t register!
With the little information provided, it is hard to help you solve your issue. Can you provide more details like your domain name and a screenshot of your DNS record from your DNS provider’s dashboard?
I added 2 other ones cause a doc said to do that idk
Since you’re using Namecheap, you might need to remove the domain name from the record’s Host field (or the one field that contains the hash), leaving only the hash as most DNS providers already add the domain name after the record’s name.
wdym “hash” please explain because what you said made no sense to me.
If your cname record is:
51f7aafae58a2ffa5f183c754a2c49c0.example.com
The 51f7aafae58a2ffa5f183c754a2c49c0 is hash, you will have to remove your domain name from the cname record since most providers add it automatically
It worked
