Urgent: MX records differ between InfinityFree nameservers for peaceu.org
https://peaceu.org
Google Workspace email receiving is failing because the MX records returned by the two InfinityFree nameservers are different.
Hello Support,
My domain is peaceu.org.
My two DNS nameservers return different MX records. One returns the old mail server with priority 0, while the other returns Google’s mail server with priority 1.
I deleted the old MX record from the DNS panel, but the results still differ.
Please synchronize the MX records on both nameservers.
Please do not change my website IP address: 185.27.134.65.
Thank you.
I need the exact results from each nameserver. Please post the nameserver hostnames you queried and the MX records each one returned (priority and mail server), ideally as the raw output of the lookup tool you used. Also post the MX records the DNS panel for peaceu.org lists right now. That would show whether the old record is still in the panel or only still being served by one nameserver.
I couldn’t find a forum topic or article about the two InfinityFree nameservers returning different MX records for the same domain. I can’t say what’s causing it yet. I also can’t synchronize the records myself. If the panel shows only the Google record and one nameserver still returns the old one after you’ve posted the details, that needs a person to look at it.
How recently did you delete it? it can take a little while for these records to be updated.
It can take a little while for all DNS servers to update. It’s usually pretty fast, but there is plenty of caching in it to keep it fast, so it can take up to an hour or so.
I just checked it and both ns1.infinityfree.com and ns2.infinityfree.com return smtp.google.com with priority 1.
My queries go to the servers in Europe, the Americas and the east of Asia usually route to one of the two locations in the US, which may have slightly different data. But also there goes: it takes little while to update due to caching.
