The uploaded file exceeds the upload_max_filesize directive in php.ini.
How To Fix ?
How To Fix ?
Just keep to below the limit.
That’s all
How big is the file?
There is a way to modify php.ini but you can’t modify upload_max_filesize with it.
edit: not direct modify the php.ini file, but in other way.
Reduce the size of the uploaded file, or find another way to get the content in.
If you want us to help with that, can you please tell us more about what exactly you’re trying to do so we see if there is a suitable workaround?
I’m certain that whatever thing is going up in your mind it won’t work here. They’re all blocked.
