Upgrade Required
The CRM that i install ask me to upgrade but i dont know where i can do it…Thanks
Upgrade Required
Current DB Version:
Current Software Version: 3.3.2
I have no idea either. But that’s mostly because that message seems to refer to the CRM itself, and I don’t even know which CRM you are talking about.
Which software do you use? And does that software have any upgrade instructions (either on the same page as where you see this message, or on the website of the software itself)?
