Upgrade my hosting plan
Hello,
When I upgrade my hosting plan, all my websites will be upgraded or I should select one website?
It will depend on what type of hosting plan you are upgrading to…
The first plan I quess
For example, if you had 2 accounts on one email, and you decided to get premium for one of them, then only that one would be on premium servers (that is, once you ask iFastNet to transfer it there).
I forgot to include that if you have more than one website on your account, all of the websites should go with.
Thanks, I got it
