Uncaught mysqli_sql_exception
internet-diving.infinityfreeapp.com
**Fatal error** : Uncaught mysqli_sql_exception: Access denied for user '[email protected]'@'192.168.0.53' (using password: YES) in /home/vol7_3/infinityfree.com/if0_36011463/htdocs/index.php:25 Stack trace: #0 /home/vol7_3/infinityfree.com/if0_36011463/htdocs/index.php(25): mysqli->__construct('sql313.inifinit...', 'PII@...', Object(SensitiveParameterValue), 'if0_36011463_in...') #1 {main} thrown in **/home/vol7_3/infinityfree.com/if0_36011463/htdocs/index.php** on line **25**
i have a config.php file that is linked to index.php with the information below
<?php
// Database credentials
define('DB_SERVER', 'sql313.inifinityfree.com');
define('DB_USERNAME', '[email protected]');
define('DB_PASSWORD', '???');
define('DB_NAME', 'if0_36011463_infodiving');
// API Keys
define('SCREENSHOT_API_KEY', '???');
define('IMGBB_API_KEY', '???');
That is not the database username. The username is if0_36011463
I tried that username - but I’m still getting the same error
Make sure you are using the password shown in the client area, NOT the password you use to signin to the dashboard
Yes, they’re completely different, the password you use for your login is not the MySQL login password. You’re able to find it in the MySQL tab.
