Typo3 installation error
epiz_26629755 http://fsociety.ml
The following errors were found :
  • Could not make the query numbered : 49
    MySQL Error No : 1071
    MySQL Error : Specified key was too long; max key length is 1000 bytes
This is the error I get when installing TYPO3 from softalculous.
Hmmm…what are you trying to install?
Hmm, Seems like Typo3 is not compatible…
Can you try to install again?
@KangJL he has mentioned it
im trying to install TYPO3 from softalculous
i tried to install it mannually but i got the same error
I believe you need to try other CMS. Installation footprint is quite large…hence sql error msg.
I believe that software is using InnoDB, which isn’t available in this hosting.
Please see this article, it references this error message:
but the older version can be installed properly without any kind of SQL problem or any other problems
That means that something changed in Typo3 which made InnoDB a requirement which it wasn’t before.
