TOS Question
Hello,
I was scrolling through the TOS to try and see if this PHP script I found would be safe to host here or not, but I didn’t find anything (Although I could have missed it). The script is linked below.
gist.github[dot]com/Logicbloke/bd97002354460e427842002a8a6a95fc
Is there something in the TOS that would prevent me from hosting this here?
Thanks
I don’t think there’s a problem with it. The only thing that I found is that all scripts must be used to display a website, but I guess that that’s what the script does.
actually i tried the script and couldn’t get it to work lol
Best to wait for the admin’s answer, though.
Worst that happens is you get suspended and they ask you to remove the file, I guess.
It’s a bit of a grey area. It could be considered a hacking script and be prohibited that way. But I don’t think anyone will care about this, so you’re probably good to go.
