Time out problem !
Every time i edit file on MonstaFTP and then go for save that file at the time its fire problem that time out to save file operation !
hi
the XHR Timeout might be turned on
is this happens if you open a file right away and click save
or you’re editing it so long so that the server will drop conn. because it thinks you’re inactive?
thanks OxyDac
:slight_smile:
I did nothing :smile: but yw
and welcome to the forum and infinityfree family
