System looked for "welcome message", then timed out after 20 seconds
Everyone, below is my 1st & 2nd attempt to login to FieZilla:
Host: infinityfree.net
User name: My bear craigslist email
Password: [CPanel pass is the same as login pass]
Port: [Left empty - default is 21]
Status: Resolving address of infinityfree.net
Status: Connecting to 104.27.16.86:21…
Status: Connection established, waiting for welcome message…
Status: Waiting to retry…
Check your host, Its not infinityfree.net. Try your FTP host
The hostname, username and password are not correct. The login details for FTP are not the same as your client area login details.
Go into the client area, find your account, click Manage and see your FTP details in the Overview tab.
Try and type all the info manually without copy and paste. If that doesn’t help check the username and the hostname like said above, but change the FTP password. I got that problem, but i fix that way. Hope you can fix it too!
Admin,
Thanks for pointing out the “Overview” info, which I plugged into the “Quick Connect” boxes. Here’s what error message I got (I even carefully re-typed the password - got the same message as below):
Status: Resolving address of ftp.epizy.com
Status: Initializing TLS…
Status: Verifying certificate…
Status: TLS connection established.
Command: USER epiz_20481292
Response: 331 User epiz_20481292 OK. Password required
Command: PASS ********
Response: 530 Login authentication failed
Error: Critical error: Could not connect to server
Status: Disconnected from server
[Deleted by MrBear - Same as above]
I just tried to login with your details but I was able to connect without any problems. Perhaps you could try copying and pasting the password from the Password tab in the client area, which has got to be less error prone than typing it manually.
